Time Before: 0.02141 seconds
Time After: 0.02923 seconds
Time Taken: 0.00782 seconds
Time Before: 0.02934 seconds
Time After: 0.02990 seconds
Time Taken: 0.00056 seconds
Time Before: 0.03011 seconds
Time After: 0.03025 seconds
Time Before: 0.03094 seconds
Time After: 0.03315 seconds
Time Taken: 0.00221 seconds
Time Before: 0.03032 seconds
Time After: 0.03696 seconds
Time Taken: 0.00664 seconds
Time Before: 0.04562 seconds
Time After: 0.04600 seconds
Time Before: 0.04841 seconds
Time After: 0.04960 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04495 seconds
Time After: 0.04982 seconds
Time Taken: 0.00487 seconds
Memory After: 2,261.820 KB
Time Before: 0.08685 seconds
Time After: 0.08701 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.10958 seconds
Time After: 0.11086 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.12727 seconds
Time After: 0.12741 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.13018 seconds
Time After: 0.13170 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789067933, location = '/forums/private.php?do=newpm&explain=1&u=100763', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.15692 seconds
Time After: 0.15720 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
