Time Before: 0.00337 seconds
Time After: 0.00549 seconds
Time Taken: 0.00212 seconds
Time Before: 0.00559 seconds
Time After: 0.00601 seconds
Time Before: 0.00625 seconds
Time After: 0.00638 seconds
Time Before: 0.00731 seconds
Time After: 0.01101 seconds
Time Taken: 0.00369 seconds
Time Before: 0.00646 seconds
Time After: 0.01445 seconds
Time Taken: 0.00799 seconds
Time Before: 0.01652 seconds
Time After: 0.01697 seconds
Time Before: 0.02029 seconds
Time After: 0.02188 seconds
Time Taken: 0.00159 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01591 seconds
Time After: 0.02206 seconds
Time Taken: 0.00615 seconds
Memory After: 2,261.703 KB
Time Before: 0.02850 seconds
Time After: 0.02868 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.03135 seconds
Time After: 0.03290 seconds
Time Taken: 0.00156 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.03767 seconds
Time After: 0.03784 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.04062 seconds
Time After: 0.04209 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100764', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05561 seconds
Time After: 0.05591 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
