Time Before: 0.00138 seconds
Time After: 0.00194 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00201 seconds
Time After: 0.00264 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00288 seconds
Time After: 0.00302 seconds
Time Before: 0.00399 seconds
Time After: 0.00664 seconds
Time Taken: 0.00265 seconds
Time Before: 0.00311 seconds
Time After: 0.01203 seconds
Time Taken: 0.00892 seconds
Time Before: 0.01451 seconds
Time After: 0.01514 seconds
Time Before: 0.01830 seconds
Time After: 0.01960 seconds
Time Before: 0.01373 seconds
Time After: 0.01978 seconds
Time Taken: 0.00606 seconds
Time Before: 0.02503 seconds
Time After: 0.02521 seconds
Time Before: 0.02743 seconds
Time After: 0.02867 seconds
End call of global.php: 0.030278921127319
Time Before: 0.03137 seconds
Time After: 0.03150 seconds
Time Before: 0.03390 seconds
Time After: 0.03533 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=100795', badlocation = 1
Time Before: 0.04787 seconds
Time After: 0.04820 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.046948909759521 seconds with 9 queries, spending 0.0086677074432373 doing MySQL queries and 0.038281202316284 doing PHP things.
