Time Before: 0.02114 seconds
Time After: 0.02850 seconds
Time Taken: 0.00736 seconds
Time Before: 0.02860 seconds
Time After: 0.02902 seconds
Time Before: 0.02925 seconds
Time After: 0.02939 seconds
Time Before: 0.03033 seconds
Time After: 0.03251 seconds
Time Taken: 0.00219 seconds
Time Before: 0.02947 seconds
Time After: 0.03645 seconds
Time Taken: 0.00698 seconds
Time Before: 0.04268 seconds
Time After: 0.04312 seconds
Time Before: 0.04615 seconds
Time After: 0.04735 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04206 seconds
Time After: 0.04755 seconds
Time Taken: 0.00549 seconds
Memory After: 2,261.820 KB
Time Before: 0.08389 seconds
Time After: 0.08409 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.10748 seconds
Time After: 0.10878 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.12429 seconds
Time After: 0.12444 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.12720 seconds
Time After: 0.12890 seconds
Time Taken: 0.00170 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788951874, location = '/forums/private.php?do=newpm&explain=1&u=100805' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.14774 seconds
Time After: 0.14818 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
