Time Before: 0.02714 seconds
Time After: 0.03593 seconds
Time Taken: 0.00879 seconds
Time Before: 0.03603 seconds
Time After: 0.03646 seconds
Time Before: 0.03674 seconds
Time After: 0.03686 seconds
Time Before: 0.03764 seconds
Time After: 0.03957 seconds
Time Taken: 0.00192 seconds
Time Before: 0.03692 seconds
Time After: 0.04378 seconds
Time Taken: 0.00686 seconds
Time Before: 0.05490 seconds
Time After: 0.05529 seconds
Time Before: 0.05768 seconds
Time After: 0.05896 seconds
Time Before: 0.05401 seconds
Time After: 0.05919 seconds
Time Taken: 0.00518 seconds
Time Before: 0.10854 seconds
Time After: 0.10869 seconds
Time Before: 0.12570 seconds
Time After: 0.12694 seconds
Time Before: 0.13829 seconds
Time After: 0.13847 seconds
Time Before: 0.14127 seconds
Time After: 0.14274 seconds
UPDATE session SET lastactivity = 1788932038, location = '/forums/private.php?do=newpm&explain=1&u=100813' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.16312 seconds
Time After: 0.16340 seconds
