Time Before: 0.00142 seconds
Time After: 0.00187 seconds
Time Before: 0.00194 seconds
Time After: 0.00246 seconds
Time Before: 0.00288 seconds
Time After: 0.00300 seconds
Time Before: 0.00412 seconds
Time After: 0.00689 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00305 seconds
Time After: 0.01116 seconds
Time Taken: 0.00811 seconds
Time Before: 0.01327 seconds
Time After: 0.01380 seconds
Time Taken: 0.00053 seconds
Time Before: 0.01704 seconds
Time After: 0.01827 seconds
Time Before: 0.01246 seconds
Time After: 0.01844 seconds
Time Taken: 0.00599 seconds
Time Before: 0.02382 seconds
Time After: 0.02394 seconds
Time Before: 0.02582 seconds
Time After: 0.02703 seconds
Time Before: 0.03009 seconds
Time After: 0.03026 seconds
Time Before: 0.03316 seconds
Time After: 0.03457 seconds
UPDATE session SET lastactivity = 1788903963, location = '/forums/private.php?do=newpm&explain=1&u=100822' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04804 seconds
Time After: 0.04869 seconds
Time Taken: 0.00065 seconds
