Time Before: 0.00733 seconds
Time After: 0.00985 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00995 seconds
Time After: 0.01036 seconds
Time Before: 0.01061 seconds
Time After: 0.01103 seconds
Time Before: 0.01219 seconds
Time After: 0.01454 seconds
Time Taken: 0.00235 seconds
Time Before: 0.01109 seconds
Time After: 0.01932 seconds
Time Taken: 0.00823 seconds
Time Before: 0.02369 seconds
Time After: 0.02414 seconds
Time Before: 0.02749 seconds
Time After: 0.02868 seconds
Time Before: 0.02294 seconds
Time After: 0.02890 seconds
Time Taken: 0.00596 seconds
Time Before: 0.04962 seconds
Time After: 0.04976 seconds
Time Before: 0.05949 seconds
Time After: 0.06075 seconds
Time Before: 0.06690 seconds
Time After: 0.06706 seconds
Time Before: 0.07015 seconds
Time After: 0.07161 seconds
UPDATE session SET lastactivity = 1785362241, location = '/forums/private.php?do=newpm&explain=1&u=100825', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.09055 seconds
Time After: 0.09090 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
