Time Before: 0.01750 seconds
Time After: 0.02355 seconds
Time Taken: 0.00606 seconds
Time Before: 0.02368 seconds
Time After: 0.02417 seconds
Time Before: 0.02448 seconds
Time After: 0.02465 seconds
Time Before: 0.02544 seconds
Time After: 0.02793 seconds
Time Taken: 0.00249 seconds
Time Before: 0.02474 seconds
Time After: 0.03221 seconds
Time Taken: 0.00748 seconds
Time Before: 0.03697 seconds
Time After: 0.03738 seconds
Time Before: 0.03992 seconds
Time After: 0.04119 seconds
Time Before: 0.03621 seconds
Time After: 0.04145 seconds
Time Taken: 0.00524 seconds
Time Before: 0.06580 seconds
Time After: 0.06599 seconds
Time Before: 0.07746 seconds
Time After: 0.07871 seconds
Time Before: 0.08526 seconds
Time After: 0.08545 seconds
Time Before: 0.08806 seconds
Time After: 0.08965 seconds
Time Taken: 0.00159 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100828' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.10636 seconds
Time After: 0.10667 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
