Time Before: 0.02842 seconds
Time After: 0.03367 seconds
Time Taken: 0.00525 seconds
Time Before: 0.03383 seconds
Time After: 0.03424 seconds
Time Before: 0.03457 seconds
Time After: 0.03475 seconds
Time Before: 0.03570 seconds
Time After: 0.03836 seconds
Time Taken: 0.00266 seconds
Time Before: 0.03484 seconds
Time After: 0.04228 seconds
Time Taken: 0.00745 seconds
Time Before: 0.05337 seconds
Time After: 0.05383 seconds
Time Before: 0.05624 seconds
Time After: 0.05748 seconds
Time Before: 0.05272 seconds
Time After: 0.05774 seconds
Time Taken: 0.00502 seconds
Time Before: 0.11069 seconds
Time After: 0.11084 seconds
Time Before: 0.12937 seconds
Time After: 0.13061 seconds
End call of global.php: 0.13275790214539
Time Before: 0.14335 seconds
Time After: 0.14349 seconds
Time Before: 0.14584 seconds
Time After: 0.14724 seconds
Time Taken: 0.00140 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=100901'
Time Before: 0.16897 seconds
Time After: 0.16923 seconds
Page generated in 0.16771793365479 seconds with 9 queries, spending 0.0081379413604736 doing MySQL queries and 0.15957999229431 doing PHP things.
