Time Before: 0.00142 seconds
Time After: 0.00193 seconds
Time Before: 0.00200 seconds
Time After: 0.00243 seconds
Time Before: 0.00267 seconds
Time After: 0.00304 seconds
Time Before: 0.00381 seconds
Time After: 0.00636 seconds
Time Taken: 0.00255 seconds
Time Before: 0.00309 seconds
Time After: 0.01102 seconds
Time Taken: 0.00793 seconds
Time Before: 0.01345 seconds
Time After: 0.01382 seconds
Time Before: 0.01656 seconds
Time After: 0.01778 seconds
Time Before: 0.01266 seconds
Time After: 0.01804 seconds
Time Taken: 0.00538 seconds
Time Before: 0.02562 seconds
Time After: 0.02575 seconds
Time Before: 0.02813 seconds
Time After: 0.02938 seconds
Time Before: 0.03422 seconds
Time After: 0.03437 seconds
Time Before: 0.03770 seconds
Time After: 0.03922 seconds
Time Taken: 0.00152 seconds
UPDATE session SET lastactivity = 1789119815, location = '/forums/private.php?do=newpm&explain=1&u=100906', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05422 seconds
Time After: 0.05452 seconds
