Time Before: 0.00154 seconds
Time After: 0.00198 seconds
Time Before: 0.00204 seconds
Time After: 0.00248 seconds
Time Before: 0.00268 seconds
Time After: 0.00280 seconds
Time Before: 0.00340 seconds
Time After: 0.00559 seconds
Time Taken: 0.00218 seconds
Time Before: 0.00285 seconds
Time After: 0.00901 seconds
Time Taken: 0.00617 seconds
Time Before: 0.01126 seconds
Time After: 0.01165 seconds
Time Before: 0.01415 seconds
Time After: 0.01537 seconds
Time Before: 0.01063 seconds
Time After: 0.01564 seconds
Time Taken: 0.00501 seconds
Time Before: 0.02093 seconds
Time After: 0.02107 seconds
Time Before: 0.02280 seconds
Time After: 0.02399 seconds
Time Before: 0.02694 seconds
Time After: 0.02712 seconds
Time Before: 0.02934 seconds
Time After: 0.03077 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100907' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04418 seconds
Time After: 0.04444 seconds
