Time Before: 0.01209 seconds
Time After: 0.01764 seconds
Time Taken: 0.00556 seconds
Time Before: 0.01776 seconds
Time After: 0.01822 seconds
Time Before: 0.01849 seconds
Time After: 0.01861 seconds
Time Before: 0.01933 seconds
Time After: 0.02191 seconds
Time Taken: 0.00258 seconds
Time Before: 0.01868 seconds
Time After: 0.02603 seconds
Time Taken: 0.00735 seconds
Time Before: 0.03262 seconds
Time After: 0.03308 seconds
Time Before: 0.03581 seconds
Time After: 0.03698 seconds
Time Taken: 0.00117 seconds
Time Before: 0.03182 seconds
Time After: 0.03720 seconds
Time Taken: 0.00538 seconds
Time Before: 0.06590 seconds
Time After: 0.06606 seconds
Time Before: 0.07755 seconds
Time After: 0.07880 seconds
End call of global.php: 0.080721855163574
Time Before: 0.08643 seconds
Time After: 0.08662 seconds
Time Before: 0.08925 seconds
Time After: 0.09071 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=100937'
Time Before: 0.10715 seconds
Time After: 0.10743 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.10612201690674 seconds with 9 queries, spending 0.0081355571746826 doing MySQL queries and 0.097986459732056 doing PHP things.
