Time Before: 0.00158 seconds
Time After: 0.00204 seconds
Time Before: 0.00212 seconds
Time After: 0.00253 seconds
Time Before: 0.00277 seconds
Time After: 0.00289 seconds
Time Before: 0.00356 seconds
Time After: 0.00560 seconds
Time Taken: 0.00204 seconds
Time Before: 0.00294 seconds
Time After: 0.00955 seconds
Time Taken: 0.00661 seconds
Time Before: 0.01188 seconds
Time After: 0.01246 seconds
Time Taken: 0.00058 seconds
Time Before: 0.01409 seconds
Time After: 0.01540 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01124 seconds
Time After: 0.01565 seconds
Time Taken: 0.00441 seconds
Time Before: 0.02144 seconds
Time After: 0.02165 seconds
Time Before: 0.02350 seconds
Time After: 0.02471 seconds
Time Before: 0.02769 seconds
Time After: 0.02782 seconds
Time Before: 0.02982 seconds
Time After: 0.03132 seconds
Time Taken: 0.00150 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100948', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04357 seconds
Time After: 0.04495 seconds
Time Taken: 0.00139 seconds
