Time Before: 0.00134 seconds
Time After: 0.00192 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00198 seconds
Time After: 0.00250 seconds
Time Before: 0.00279 seconds
Time After: 0.00298 seconds
Time Before: 0.00384 seconds
Time After: 0.00709 seconds
Time Taken: 0.00324 seconds
Time Before: 0.00306 seconds
Time After: 0.01053 seconds
Time Taken: 0.00747 seconds
Time Before: 0.01239 seconds
Time After: 0.01286 seconds
Time Before: 0.01581 seconds
Time After: 0.01731 seconds
Time Taken: 0.00150 seconds
Time Before: 0.01181 seconds
Time After: 0.01748 seconds
Time Taken: 0.00568 seconds
Time Before: 0.02427 seconds
Time After: 0.02449 seconds
Time Before: 0.02657 seconds
Time After: 0.02781 seconds
Time Before: 0.03069 seconds
Time After: 0.03086 seconds
Time Before: 0.03281 seconds
Time After: 0.03431 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100955' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.04672 seconds
Time After: 0.04711 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
