Time Before: 0.01918 seconds
Time After: 0.02593 seconds
Time Taken: 0.00675 seconds
Time Before: 0.02601 seconds
Time After: 0.02656 seconds
Time Taken: 0.00055 seconds
Time Before: 0.02685 seconds
Time After: 0.02702 seconds
Time Before: 0.02793 seconds
Time After: 0.03109 seconds
Time Taken: 0.00316 seconds
Time Before: 0.02707 seconds
Time After: 0.03529 seconds
Time Taken: 0.00822 seconds
Time Before: 0.04070 seconds
Time After: 0.04090 seconds
Time Before: 0.04417 seconds
Time After: 0.04544 seconds
Time Before: 0.03997 seconds
Time After: 0.04566 seconds
Time Taken: 0.00569 seconds
Time Before: 0.07763 seconds
Time After: 0.07782 seconds
Time Before: 0.30269 seconds
Time After: 0.30393 seconds
Time Before: 0.31247 seconds
Time After: 0.31262 seconds
Time Before: 0.31525 seconds
Time After: 0.31669 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100956', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.33264 seconds
Time After: 0.33289 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
