Time Before: 0.00170 seconds
Time After: 0.00220 seconds
Time Before: 0.00227 seconds
Time After: 0.00269 seconds
Time Before: 0.00286 seconds
Time After: 0.00300 seconds
Time Before: 0.00368 seconds
Time After: 0.00615 seconds
Time Taken: 0.00246 seconds
Time Before: 0.00305 seconds
Time After: 0.01043 seconds
Time Taken: 0.00738 seconds
Time Before: 0.01341 seconds
Time After: 0.01387 seconds
Time Before: 0.01717 seconds
Time After: 0.01837 seconds
Time Before: 0.01247 seconds
Time After: 0.01865 seconds
Time Taken: 0.00619 seconds
Time Before: 0.02560 seconds
Time After: 0.02578 seconds
Time Before: 0.02794 seconds
Time After: 0.02924 seconds
End call of global.php: 0.032142162322998
Time Before: 0.03383 seconds
Time After: 0.03398 seconds
Time Before: 0.03694 seconds
Time After: 0.03836 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=100957'
Time Before: 0.05545 seconds
Time After: 0.05578 seconds
Page generated in 0.054497957229614 seconds with 9 queries, spending 0.0080564022064209 doing MySQL queries and 0.046441555023193 doing PHP things.
