Time Before: 0.01346 seconds
Time After: 0.01789 seconds
Time Taken: 0.00442 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.01803 seconds
Time After: 0.01848 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.01878 seconds
Time After: 0.01894 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.01979 seconds
Time After: 0.02227 seconds
Time Taken: 0.00249 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.01902 seconds
Time After: 0.02637 seconds
Time Taken: 0.00735 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.195 KB
Time Before: 0.03172 seconds
Time After: 0.03217 seconds
Memory Before: 2,758.008 KB
Memory After: 2,758.625 KB
Time Before: 0.03476 seconds
Time After: 0.03593 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,770.180 KB
Memory After: 2,770.039 KB
Time Before: 0.03092 seconds
Time After: 0.03614 seconds
Time Taken: 0.00522 seconds
Memory Before: 2,750.156 KB
Memory After: 2,883.398 KB
Memory Used: 133.242 KB
Time Before: 0.06481 seconds
Time After: 0.06495 seconds
Memory Before: 3,436.508 KB
Memory After: 3,437.023 KB
REPLACE INTO datastore
	(title, data, unserialize)
VALUES
	('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"20.51,\";s:9:\"lastcheck\";i:1782843484;}', 1)
Time Before: 0.07659 seconds
Time After: 0.07722 seconds
Time Taken: 0.00064 seconds
Memory Before: 3,437.773 KB
Memory After: 3,438.023 KB
Memory Used: 0.250 KB
Time Before: 0.09133 seconds
Time After: 0.09275 seconds
Memory Before: 3,524.672 KB
Memory After: 3,525.266 KB
End call of global.php: 0.095938920974731
Time Before: 0.10061 seconds
Time After: 0.10079 seconds
Memory Before: 4,162.594 KB
Memory After: 4,163.023 KB
Time Before: 0.10345 seconds
Time After: 0.10491 seconds
Memory Before: 4,444.242 KB
Memory After: 4,445.930 KB
SET lastactivity = 1782843484, location = '/forums/private.php?do=newpm&explain=1&u=100966', badlocation = 1
WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.12438 seconds
Time After: 0.12472 seconds
Memory Before: 4,922.734 KB
Memory After: 4,922.945 KB
Page generated in 0.12318897247314 seconds with 10 queries, spending 0.0089023113250732 doing MySQL queries and 0.11428666114807 doing PHP things.
