Time Before: 0.02558 seconds
Time After: 0.03412 seconds
Time Taken: 0.00854 seconds
Time Before: 0.03424 seconds
Time After: 0.03481 seconds
Time Taken: 0.00058 seconds
Time Before: 0.03516 seconds
Time After: 0.03557 seconds
Time Before: 0.03647 seconds
Time After: 0.03891 seconds
Time Taken: 0.00243 seconds
Time Before: 0.03565 seconds
Time After: 0.04311 seconds
Time Taken: 0.00745 seconds
Time Before: 0.04853 seconds
Time After: 0.04880 seconds
Time Before: 0.05139 seconds
Time After: 0.05273 seconds
Time Taken: 0.00134 seconds
Time Before: 0.04778 seconds
Time After: 0.05297 seconds
Time Taken: 0.00519 seconds
Time Before: 0.09292 seconds
Time After: 0.09309 seconds
Time Before: 0.10993 seconds
Time After: 0.11124 seconds
Time Taken: 0.00131 seconds
Time Before: 0.12335 seconds
Time After: 0.12358 seconds
Time Before: 0.12729 seconds
Time After: 0.12879 seconds
UPDATE session SET lastactivity = 1783044232, location = '/forums/private.php?do=newpm&explain=1&u=100968' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.15345 seconds
Time After: 0.15376 seconds
