Time Before: 0.00866 seconds
Time After: 0.01044 seconds
Time Taken: 0.00179 seconds
Time Before: 0.01052 seconds
Time After: 0.01091 seconds
Time Before: 0.01117 seconds
Time After: 0.01129 seconds
Time Before: 0.01207 seconds
Time After: 0.01457 seconds
Time Taken: 0.00250 seconds
Time Before: 0.01136 seconds
Time After: 0.01904 seconds
Time Taken: 0.00769 seconds
Time Before: 0.02333 seconds
Time After: 0.02367 seconds
Time Before: 0.02592 seconds
Time After: 0.02709 seconds
Time Taken: 0.00117 seconds
Time Before: 0.02264 seconds
Time After: 0.02730 seconds
Time Taken: 0.00467 seconds
Time Before: 0.04456 seconds
Time After: 0.04469 seconds
Time Before: 0.05093 seconds
Time After: 0.05218 seconds
End call of global.php: 0.054778099060059
Time Before: 0.05819 seconds
Time After: 0.05833 seconds
Time Before: 0.06090 seconds
Time After: 0.06229 seconds
Time Taken: 0.00138 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=100976', badlocation = 1
Time Before: 0.07625 seconds
Time After: 0.07649 seconds
Page generated in 0.075313091278076 seconds with 9 queries, spending 0.0076549053192139 doing MySQL queries and 0.067658185958862 doing PHP things.
