Time Before: 0.00144 seconds
Time After: 0.00190 seconds
Time Before: 0.00197 seconds
Time After: 0.00239 seconds
Time Before: 0.00276 seconds
Time After: 0.00293 seconds
Time Before: 0.00382 seconds
Time After: 0.00673 seconds
Time Taken: 0.00290 seconds
Time Before: 0.00300 seconds
Time After: 0.01151 seconds
Time Taken: 0.00850 seconds
Time Before: 0.01330 seconds
Time After: 0.01366 seconds
Time Before: 0.01618 seconds
Time After: 0.01748 seconds
Time Before: 0.01270 seconds
Time After: 0.01773 seconds
Time Taken: 0.00504 seconds
Time Before: 0.02423 seconds
Time After: 0.02447 seconds
Time Before: 0.02717 seconds
Time After: 0.02850 seconds
Time Taken: 0.00134 seconds
End call of global.php: 0.030812978744507
Time Before: 0.03228 seconds
Time After: 0.03245 seconds
Time Before: 0.03502 seconds
Time After: 0.03652 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1788978785, location = '/forums/private.php?do=newpm&explain=1&u=100983'
Time Before: 0.05049 seconds
Time After: 0.05091 seconds
Page generated in 0.049593925476074 seconds with 9 queries, spending 0.0088088512420654 doing MySQL queries and 0.040785074234009 doing PHP things.
