Time Before: 0.00145 seconds
Time After: 0.00206 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00217 seconds
Time After: 0.00267 seconds
Time Before: 0.00295 seconds
Time After: 0.00311 seconds
Time Before: 0.00389 seconds
Time After: 0.00651 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00316 seconds
Time After: 0.01165 seconds
Time Taken: 0.00849 seconds
Time Before: 0.01349 seconds
Time After: 0.01373 seconds
Time Before: 0.01629 seconds
Time After: 0.01759 seconds
Time Before: 0.01289 seconds
Time After: 0.01783 seconds
Time Taken: 0.00495 seconds
Time Before: 0.02316 seconds
Time After: 0.02328 seconds
Time Before: 0.06398 seconds
Time After: 0.06526 seconds
Time Before: 0.06873 seconds
Time After: 0.06889 seconds
Time Before: 0.07126 seconds
Time After: 0.07273 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100999', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.08701 seconds
Time After: 0.08725 seconds
