Time Before: 0.00163 seconds
Time After: 0.00215 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00226 seconds
Time After: 0.00306 seconds
Time Taken: 0.00081 seconds
Time Before: 0.00341 seconds
Time After: 0.00356 seconds
Time Before: 0.00428 seconds
Time After: 0.00700 seconds
Time Taken: 0.00272 seconds
Time Before: 0.00362 seconds
Time After: 0.01059 seconds
Time Taken: 0.00697 seconds
Time Before: 0.01244 seconds
Time After: 0.01287 seconds
Time Before: 0.01528 seconds
Time After: 0.01655 seconds
Time Before: 0.01179 seconds
Time After: 0.01673 seconds
Time Taken: 0.00494 seconds
Time Before: 0.02182 seconds
Time After: 0.02204 seconds
Time Before: 0.02426 seconds
Time After: 0.02561 seconds
Time Taken: 0.00134 seconds
End call of global.php: 0.027308940887451
Time Before: 0.02850 seconds
Time After: 0.02866 seconds
Time Before: 0.03079 seconds
Time After: 0.03227 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=101005', badlocation = 1
Time Before: 0.04530 seconds
Time After: 0.04560 seconds
Page generated in 0.044380903244019 seconds with 9 queries, spending 0.0088968276977539 doing MySQL queries and 0.035484075546265 doing PHP things.
