Time Before: 0.03186 seconds
Time After: 0.04050 seconds
Time Taken: 0.00864 seconds
Time Before: 0.04058 seconds
Time After: 0.04122 seconds
Time Taken: 0.00064 seconds
Time Before: 0.04147 seconds
Time After: 0.04161 seconds
Time Before: 0.04240 seconds
Time After: 0.04483 seconds
Time Taken: 0.00243 seconds
Time Before: 0.04168 seconds
Time After: 0.04924 seconds
Time Taken: 0.00756 seconds
Time Before: 0.05628 seconds
Time After: 0.05649 seconds
Time Before: 0.05797 seconds
Time After: 0.05961 seconds
Time Taken: 0.00163 seconds
Time Before: 0.05556 seconds
Time After: 0.05984 seconds
Time Taken: 0.00429 seconds
Time Before: 0.09595 seconds
Time After: 0.09618 seconds
Time Before: 0.68784 seconds
Time After: 0.68963 seconds
Time Taken: 0.00178 seconds
Time Before: 0.69907 seconds
Time After: 0.69925 seconds
Time Before: 0.70150 seconds
Time After: 0.70384 seconds
Time Taken: 0.00234 seconds
UPDATE session SET lastactivity = 1783045651, location = '/forums/private.php?do=newpm&explain=1&u=101008' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.72513 seconds
Time After: 0.72544 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
