Time Before: 0.03653 seconds
Time After: 0.04598 seconds
Time Taken: 0.00946 seconds
Memory Before: 1,244.094 KB
Memory After: 1,270.898 KB
Time Before: 0.04614 seconds
Time After: 0.04658 seconds
Memory Before: 1,270.859 KB
Memory After: 1,271.836 KB
Time Before: 0.04685 seconds
Time After: 0.04696 seconds
Memory Before: 1,272.477 KB
Memory After: 1,273.000 KB
Time Before: 0.04799 seconds
Time After: 0.05052 seconds
Time Taken: 0.00253 seconds
Memory Before: 1,275.867 KB
Memory After: 1,276.789 KB
Time Before: 0.04703 seconds
Time After: 0.05568 seconds
Time Taken: 0.00865 seconds
Memory Before: 1,272.281 KB
Memory After: 2,353.516 KB
Memory Used: 1,081.234 KB
Time Before: 0.06488 seconds
Time After: 0.06529 seconds
Memory Before: 2,893.773 KB
Memory After: 2,894.391 KB
Time Before: 0.06803 seconds
Time After: 0.06922 seconds
Memory Before: 2,906.219 KB
Memory After: 2,906.078 KB
Time Before: 0.06404 seconds
Time After: 0.06955 seconds
Time Taken: 0.00550 seconds
Memory Before: 2,886.500 KB
Memory After: 3,019.500 KB
Memory Used: 133.000 KB
Time Before: 0.10452 seconds
Time After: 0.10466 seconds
Memory Before: 3,654.063 KB
Memory After: 3,654.578 KB
Time Before: 0.16730 seconds
Time After: 0.16857 seconds
Memory Before: 4,131.688 KB
Memory After: 4,132.281 KB
Time Before: 0.19448 seconds
Time After: 0.19463 seconds
Memory Before: 5,195.945 KB
Memory After: 5,324.289 KB
Time Before: 0.20092 seconds
Time After: 0.20237 seconds
Memory Before: 5,479.641 KB
Memory After: 5,609.242 KB
UPDATE session SET lastactivity = 1772805025, location = '/forums/private.php?do=newpm&explain=1&u=101010', badlocation = 1 WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.23355 seconds
Time After: 0.23382 seconds
Memory Before: 6,009.117 KB
Memory After: 6,009.328 KB
