Time Before: 0.00146 seconds
Time After: 0.00192 seconds
Time Before: 0.00199 seconds
Time After: 0.00232 seconds
Time Before: 0.00250 seconds
Time After: 0.00264 seconds
Time Before: 0.00331 seconds
Time After: 0.00583 seconds
Time Taken: 0.00252 seconds
Time Before: 0.00269 seconds
Time After: 0.00917 seconds
Time Taken: 0.00648 seconds
Time Before: 0.01092 seconds
Time After: 0.01130 seconds
Time Before: 0.01370 seconds
Time After: 0.01488 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01031 seconds
Time After: 0.01505 seconds
Time Taken: 0.00474 seconds
Time Before: 0.02011 seconds
Time After: 0.02029 seconds
Time Before: 0.02234 seconds
Time After: 0.02359 seconds
End call of global.php: 0.026122093200684
Time Before: 0.02740 seconds
Time After: 0.02766 seconds
Time Before: 0.02964 seconds
Time After: 0.03106 seconds
SET lastactivity = 1776793014, location = '/forums/private.php?do=newpm&explain=1&u=101013'
Time Before: 0.04368 seconds
Time After: 0.04400 seconds
Page generated in 0.042780876159668 seconds with 9 queries, spending 0.0079917907714844 doing MySQL queries and 0.034789085388184 doing PHP things.
