Time Before: 0.00132 seconds
Time After: 0.00217 seconds
Time Taken: 0.00085 seconds
Time Before: 0.00227 seconds
Time After: 0.00287 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00316 seconds
Time After: 0.00331 seconds
Time Before: 0.00397 seconds
Time After: 0.00696 seconds
Time Taken: 0.00299 seconds
Time Before: 0.00337 seconds
Time After: 0.01234 seconds
Time Taken: 0.00897 seconds
Time Before: 0.01499 seconds
Time After: 0.01600 seconds
Time Taken: 0.00101 seconds
Time Before: 0.01872 seconds
Time After: 0.02000 seconds
Time Before: 0.01406 seconds
Time After: 0.02022 seconds
Time Taken: 0.00617 seconds
Time Before: 0.02580 seconds
Time After: 0.02613 seconds
Time Before: 0.02838 seconds
Time After: 0.02978 seconds
Time Taken: 0.00140 seconds
Time Before: 0.03367 seconds
Time After: 0.03386 seconds
Time Before: 0.03639 seconds
Time After: 0.03793 seconds
Time Taken: 0.00155 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101041', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05353 seconds
Time After: 0.05422 seconds
Time Taken: 0.00069 seconds
