Time Before: 0.00186 seconds
Time After: 0.00233 seconds
Time Before: 0.00240 seconds
Time After: 0.00276 seconds
Time Before: 0.00302 seconds
Time After: 0.00314 seconds
Time Before: 0.00378 seconds
Time After: 0.00644 seconds
Time Taken: 0.00266 seconds
Time Before: 0.00319 seconds
Time After: 0.00977 seconds
Time Taken: 0.00658 seconds
Time Before: 0.01152 seconds
Time After: 0.01193 seconds
Time Before: 0.01432 seconds
Time After: 0.01556 seconds
Time Before: 0.01096 seconds
Time After: 0.01577 seconds
Time Taken: 0.00481 seconds
Time Before: 0.02144 seconds
Time After: 0.02159 seconds
Time Before: 0.02383 seconds
Time After: 0.02507 seconds
Time Before: 0.02815 seconds
Time After: 0.02833 seconds
Time Before: 0.03121 seconds
Time After: 0.03268 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101066', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04755 seconds
Time After: 0.04785 seconds
