Time Before: 0.00139 seconds
Time After: 0.00193 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00200 seconds
Time After: 0.00243 seconds
Time Before: 0.00276 seconds
Time After: 0.00290 seconds
Time Before: 0.00376 seconds
Time After: 0.00645 seconds
Time Taken: 0.00270 seconds
Time Before: 0.00296 seconds
Time After: 0.01154 seconds
Time Taken: 0.00858 seconds
Time Before: 0.01347 seconds
Time After: 0.01388 seconds
Time Before: 0.01651 seconds
Time After: 0.01778 seconds
Time Before: 0.01281 seconds
Time After: 0.01803 seconds
Time Taken: 0.00522 seconds
Time Before: 0.02455 seconds
Time After: 0.02479 seconds
Time Before: 0.02687 seconds
Time After: 0.02814 seconds
Time Before: 0.03112 seconds
Time After: 0.03128 seconds
Time Before: 0.03360 seconds
Time After: 0.03505 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101076' WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.05081 seconds
Time After: 0.05107 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
