Time Before: 0.00726 seconds
Time After: 0.00882 seconds
Time Taken: 0.00156 seconds
Time Before: 0.00892 seconds
Time After: 0.00944 seconds
Time Before: 0.00971 seconds
Time After: 0.00986 seconds
Time Before: 0.01061 seconds
Time After: 0.01320 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00993 seconds
Time After: 0.01765 seconds
Time Taken: 0.00772 seconds
Time Before: 0.02150 seconds
Time After: 0.02193 seconds
Time Before: 0.02348 seconds
Time After: 0.02466 seconds
Time Before: 0.02072 seconds
Time After: 0.02488 seconds
Time Taken: 0.00417 seconds
Time Before: 0.04669 seconds
Time After: 0.04684 seconds
Time Before: 0.05510 seconds
Time After: 0.05635 seconds
Time Before: 0.06203 seconds
Time After: 0.06219 seconds
Time Before: 0.06458 seconds
Time After: 0.06602 seconds
UPDATE session SET lastactivity = 1776638347, location = '/forums/private.php?do=newpm&explain=1&u=101083' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.08418 seconds
Time After: 0.08558 seconds
Time Taken: 0.00140 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
