Time Before: 0.00245 seconds
Time After: 0.00327 seconds
Time Taken: 0.00083 seconds
Time Before: 0.00335 seconds
Time After: 0.00369 seconds
Time Before: 0.00387 seconds
Time After: 0.00407 seconds
Time Before: 0.00495 seconds
Time After: 0.00807 seconds
Time Taken: 0.00313 seconds
Time Before: 0.00416 seconds
Time After: 0.01251 seconds
Time Taken: 0.00835 seconds
Time Before: 0.01500 seconds
Time After: 0.01519 seconds
Time Before: 0.01777 seconds
Time After: 0.01899 seconds
Time Before: 0.01439 seconds
Time After: 0.01924 seconds
Time Taken: 0.00485 seconds
Time Before: 0.02618 seconds
Time After: 0.02633 seconds
Time Before: 0.02916 seconds
Time After: 0.03052 seconds
Time Taken: 0.00137 seconds
Time Before: 0.03620 seconds
Time After: 0.03640 seconds
Time Before: 0.03858 seconds
Time After: 0.04008 seconds
Time Taken: 0.00150 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101084' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.05950 seconds
Time After: 0.05992 seconds
