Time Before: 0.00141 seconds
Time After: 0.00192 seconds
Time Before: 0.00200 seconds
Time After: 0.00267 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00293 seconds
Time After: 0.00310 seconds
Time Before: 0.00378 seconds
Time After: 0.00643 seconds
Time Taken: 0.00265 seconds
Time Before: 0.00315 seconds
Time After: 0.00975 seconds
Time Taken: 0.00660 seconds
Time Before: 0.01198 seconds
Time After: 0.01304 seconds
Time Taken: 0.00107 seconds
Time Before: 0.01555 seconds
Time After: 0.01696 seconds
Time Before: 0.01095 seconds
Time After: 0.01714 seconds
Time Taken: 0.00620 seconds
Time Before: 0.02222 seconds
Time After: 0.02245 seconds
Time Before: 0.02432 seconds
Time After: 0.02563 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.027227163314819
Time Before: 0.02852 seconds
Time After: 0.02879 seconds
Time Before: 0.03110 seconds
Time After: 0.03255 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=101086'
Time Before: 0.04568 seconds
Time After: 0.04604 seconds
Page generated in 0.044770002365112 seconds with 9 queries, spending 0.0096044540405273 doing MySQL queries and 0.035165548324585 doing PHP things.
