Time Before: 0.00198 seconds
Time After: 0.00255 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00262 seconds
Time After: 0.00319 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00346 seconds
Time After: 0.00364 seconds
Time Before: 0.00455 seconds
Time After: 0.00719 seconds
Time Taken: 0.00264 seconds
Time Before: 0.00370 seconds
Time After: 0.01168 seconds
Time Taken: 0.00798 seconds
Time Before: 0.01359 seconds
Time After: 0.01394 seconds
Time Before: 0.01657 seconds
Time After: 0.01774 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01302 seconds
Time After: 0.01792 seconds
Time Taken: 0.00490 seconds
Time Before: 0.02382 seconds
Time After: 0.02395 seconds
Time Before: 0.02660 seconds
Time After: 0.02792 seconds
Time Taken: 0.00132 seconds
Time Before: 0.03185 seconds
Time After: 0.03199 seconds
Time Before: 0.03472 seconds
Time After: 0.03621 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101097', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.05096 seconds
Time After: 0.05122 seconds
