Time Before: 0.02726 seconds
Time After: 0.03586 seconds
Time Taken: 0.00860 seconds
Time Before: 0.03594 seconds
Time After: 0.03636 seconds
Time Before: 0.03659 seconds
Time After: 0.03676 seconds
Time Before: 0.03789 seconds
Time After: 0.03994 seconds
Time Taken: 0.00205 seconds
Time Before: 0.03682 seconds
Time After: 0.04388 seconds
Time Taken: 0.00705 seconds
Time Before: 0.05655 seconds
Time After: 0.05801 seconds
Time Before: 0.06077 seconds
Time After: 0.06216 seconds
Time Taken: 0.00140 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.05511 seconds
Time After: 0.06241 seconds
Time Taken: 0.00730 seconds
Memory After: 2,261.820 KB
Time Before: 0.09437 seconds
Time After: 0.09454 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.17240 seconds
Time After: 0.17364 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.18434 seconds
Time After: 0.18451 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.18703 seconds
Time After: 0.18847 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788912589, location = '/forums/private.php?do=newpm&explain=1&u=101103', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.21228 seconds
Time After: 0.21256 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
