Time Before: 0.02422 seconds
Time After: 0.03456 seconds
Time Taken: 0.01033 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.03469 seconds
Time After: 0.03513 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.03540 seconds
Time After: 0.03553 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.03648 seconds
Time After: 0.03861 seconds
Time Taken: 0.00212 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.03562 seconds
Time After: 0.04206 seconds
Time Taken: 0.00644 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.195 KB
Time Before: 0.05108 seconds
Time After: 0.05152 seconds
Memory Before: 2,758.008 KB
Memory After: 2,758.625 KB
Time Before: 0.05485 seconds
Time After: 0.05608 seconds
Memory Before: 2,770.180 KB
Memory After: 2,770.039 KB
Time Before: 0.05040 seconds
Time After: 0.05633 seconds
Time Taken: 0.00593 seconds
Memory Before: 2,750.156 KB
Memory After: 2,883.398 KB
Memory Used: 133.242 KB
Time Before: 0.10011 seconds
Time After: 0.10026 seconds
Memory Before: 3,436.508 KB
Memory After: 3,437.023 KB
Time Before: 0.12563 seconds
Time After: 0.12686 seconds
Memory Before: 3,524.281 KB
Memory After: 3,524.875 KB
Time Before: 0.14228 seconds
Time After: 0.14244 seconds
Memory Before: 4,162.195 KB
Memory After: 4,162.625 KB
Time Before: 0.14518 seconds
Time After: 0.14661 seconds
Memory Before: 4,443.734 KB
Memory After: 4,445.422 KB
UPDATE session SET lastactivity = 1783125357, location = '/forums/private.php?do=newpm&explain=1&u=101127' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.16231 seconds
Time After: 0.16261 seconds
Memory Before: 4,923.023 KB
Memory After: 4,923.250 KB
