Time Before: 0.00154 seconds
Time After: 0.00203 seconds
Time Before: 0.00209 seconds
Time After: 0.00267 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00290 seconds
Time After: 0.00303 seconds
Time Before: 0.00375 seconds
Time After: 0.00627 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00308 seconds
Time After: 0.00969 seconds
Time Taken: 0.00661 seconds
Time Before: 0.01182 seconds
Time After: 0.01221 seconds
Time Before: 0.01355 seconds
Time After: 0.01484 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01111 seconds
Time After: 0.01502 seconds
Time Taken: 0.00391 seconds
Memory After: 2,261.703 KB
Time Before: 0.02127 seconds
Time After: 0.02142 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02337 seconds
Time After: 0.02464 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.02778 seconds
Time After: 0.02792 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.02998 seconds
Time After: 0.03139 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101137', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04640 seconds
Time After: 0.04670 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
