Time Before: 0.00144 seconds
Time After: 0.00196 seconds
Time Before: 0.00203 seconds
Time After: 0.00260 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00287 seconds
Time After: 0.00300 seconds
Time Before: 0.00364 seconds
Time After: 0.00609 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00305 seconds
Time After: 0.00950 seconds
Time Taken: 0.00645 seconds
Time Before: 0.01170 seconds
Time After: 0.01224 seconds
Time Taken: 0.00054 seconds
Time Before: 0.01472 seconds
Time After: 0.01600 seconds
Time Before: 0.01092 seconds
Time After: 0.01617 seconds
Time Taken: 0.00524 seconds
Time Before: 0.02165 seconds
Time After: 0.02189 seconds
Time Before: 0.02454 seconds
Time After: 0.02585 seconds
End call of global.php: 0.027594089508057
Time Before: 0.02892 seconds
Time After: 0.02905 seconds
Time Before: 0.03106 seconds
Time After: 0.03247 seconds
SET lastactivity = 1782887412, location = '/forums/private.php?do=newpm&explain=1&u=101151', badlocation = 1
Time Before: 0.04490 seconds
Time After: 0.04519 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
Page generated in 0.044006109237671 seconds with 9 queries, spending 0.0083441734313965 doing MySQL queries and 0.035661935806274 doing PHP things.
