Time Before: 0.03164 seconds
Time After: 0.04686 seconds
Time Taken: 0.01522 seconds
Time Before: 0.04698 seconds
Time After: 0.04746 seconds
Time Before: 0.04772 seconds
Time After: 0.04782 seconds
Time Before: 0.04869 seconds
Time After: 0.05157 seconds
Time Taken: 0.00288 seconds
Time Before: 0.04789 seconds
Time After: 0.05594 seconds
Time Taken: 0.00805 seconds
Time Before: 0.06861 seconds
Time After: 0.06898 seconds
Time Before: 0.07159 seconds
Time After: 0.07282 seconds
Time Before: 0.06777 seconds
Time After: 0.07306 seconds
Time Taken: 0.00529 seconds
Time Before: 0.11898 seconds
Time After: 0.11911 seconds
Time Before: 0.14950 seconds
Time After: 0.15080 seconds
Time Taken: 0.00131 seconds
Time Before: 0.17113 seconds
Time After: 0.17129 seconds
Time Before: 0.17434 seconds
Time After: 0.17581 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101156', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.19682 seconds
Time After: 0.19707 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
