Time Before: 0.00139 seconds
Time After: 0.00193 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00200 seconds
Time After: 0.00247 seconds
Time Before: 0.00272 seconds
Time After: 0.00284 seconds
Time Before: 0.00372 seconds
Time After: 0.00624 seconds
Time Taken: 0.00252 seconds
Time Before: 0.00292 seconds
Time After: 0.00989 seconds
Time Taken: 0.00697 seconds
Time Before: 0.01223 seconds
Time After: 0.01277 seconds
Time Before: 0.01542 seconds
Time After: 0.01660 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01166 seconds
Time After: 0.01678 seconds
Time Taken: 0.00512 seconds
Memory After: 2,261.820 KB
Time Before: 0.02199 seconds
Time After: 0.02210 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02394 seconds
Time After: 0.02520 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.027854919433594
Time Before: 0.02929 seconds
Time After: 0.02947 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03270 seconds
Time After: 0.03455 seconds
Time Taken: 0.00185 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788969967, location = '/forums/private.php?do=newpm&explain=1&u=101161'
Time Before: 0.05252 seconds
Time After: 0.05291 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.051599979400635 seconds with 9 queries, spending 0.0086348056793213 doing MySQL queries and 0.042965173721313 doing PHP things.
