Time Before: 0.03478 seconds
Time After: 0.04566 seconds
Time Taken: 0.01088 seconds
Time Before: 0.04576 seconds
Time After: 0.04629 seconds
Time Before: 0.04654 seconds
Time After: 0.04667 seconds
Time Before: 0.04734 seconds
Time After: 0.05014 seconds
Time Taken: 0.00281 seconds
Time Before: 0.04672 seconds
Time After: 0.05430 seconds
Time Taken: 0.00757 seconds
Time Before: 0.06878 seconds
Time After: 0.06947 seconds
Time Taken: 0.00069 seconds
Time Before: 0.07242 seconds
Time After: 0.07380 seconds
Time Taken: 0.00138 seconds
Time Before: 0.06809 seconds
Time After: 0.07398 seconds
Time Taken: 0.00589 seconds
Time Before: 0.12783 seconds
Time After: 0.12797 seconds
Time Before: 0.15497 seconds
Time After: 0.15623 seconds
Time Before: 0.17450 seconds
Time After: 0.17469 seconds
Time Before: 0.17743 seconds
Time After: 0.17888 seconds
UPDATE session SET lastactivity = 1780640612, location = '/forums/private.php?do=newpm&explain=1&u=101167' WHERE sessionhash = 'f0a2de90bc45baf36aaf71071f1bfe42'
Time Before: 0.19852 seconds
Time After: 0.19887 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
