Time Before: 0.01139 seconds
Time After: 0.01565 seconds
Time Taken: 0.00425 seconds
Time Before: 0.01572 seconds
Time After: 0.01618 seconds
Time Before: 0.01640 seconds
Time After: 0.01659 seconds
Time Before: 0.01725 seconds
Time After: 0.01973 seconds
Time Taken: 0.00249 seconds
Time Before: 0.01664 seconds
Time After: 0.02381 seconds
Time Taken: 0.00718 seconds
Time Before: 0.02980 seconds
Time After: 0.03027 seconds
Time Before: 0.03279 seconds
Time After: 0.03425 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02911 seconds
Time After: 0.03444 seconds
Time Taken: 0.00533 seconds
Memory After: 2,261.820 KB
Time Before: 0.05654 seconds
Time After: 0.05673 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.07209 seconds
Time After: 0.07343 seconds
Time Taken: 0.00134 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.08270 seconds
Time After: 0.08296 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.08552 seconds
Time After: 0.08699 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789115735, location = '/forums/private.php?do=newpm&explain=1&u=101169' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.10509 seconds
Time After: 0.10536 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
