Time Before: 0.00866 seconds
Time After: 0.01084 seconds
Time Taken: 0.00218 seconds
Time Before: 0.01094 seconds
Time After: 0.01139 seconds
Time Before: 0.01163 seconds
Time After: 0.01176 seconds
Time Before: 0.01251 seconds
Time After: 0.01477 seconds
Time Taken: 0.00225 seconds
Time Before: 0.01182 seconds
Time After: 0.01903 seconds
Time Taken: 0.00721 seconds
Time Before: 0.02257 seconds
Time After: 0.02299 seconds
Time Before: 0.02551 seconds
Time After: 0.02670 seconds
Time Before: 0.02193 seconds
Time After: 0.02695 seconds
Time Taken: 0.00502 seconds
Time Before: 0.04086 seconds
Time After: 0.04128 seconds
Time Before: 0.05013 seconds
Time After: 0.05140 seconds
End call of global.php: 0.053786993026733
Time Before: 0.05685 seconds
Time After: 0.05700 seconds
Time Before: 0.05969 seconds
Time After: 0.06114 seconds
SET lastactivity = 1776659628, location = '/forums/private.php?do=newpm&explain=1&u=101194', badlocation = 1
Time Before: 0.07753 seconds
Time After: 0.07783 seconds
Page generated in 0.076446056365967 seconds with 9 queries, spending 0.0080299377441406 doing MySQL queries and 0.068416118621826 doing PHP things.
