Time Before: 0.00158 seconds
Time After: 0.00227 seconds
Time Taken: 0.00069 seconds
Time Before: 0.00235 seconds
Time After: 0.00282 seconds
Time Before: 0.00317 seconds
Time After: 0.00334 seconds
Time Before: 0.00429 seconds
Time After: 0.00742 seconds
Time Taken: 0.00313 seconds
Time Before: 0.00343 seconds
Time After: 0.01193 seconds
Time Taken: 0.00850 seconds
Time Before: 0.01395 seconds
Time After: 0.01442 seconds
Time Before: 0.01706 seconds
Time After: 0.01838 seconds
Time Taken: 0.00132 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01318 seconds
Time After: 0.01863 seconds
Time Taken: 0.00545 seconds
Memory After: 2,261.836 KB
Time Before: 0.02432 seconds
Time After: 0.02449 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02687 seconds
Time After: 0.02816 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.030988931655884
Time Before: 0.03235 seconds
Time After: 0.03250 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.03502 seconds
Time After: 0.03650 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789060817, location = '/forums/private.php?do=newpm&explain=1&u=1012', badlocation = 1
Time Before: 0.05157 seconds
Time After: 0.05190 seconds
Memory Before: 4,287.867 KB
Memory After: 4,288.078 KB
Page generated in 0.050524950027466 seconds with 9 queries, spending 0.0089700222015381 doing MySQL queries and 0.041554927825928 doing PHP things.
