Time Before: 0.00819 seconds
Time After: 0.00997 seconds
Time Taken: 0.00178 seconds
Time Before: 0.01006 seconds
Time After: 0.01047 seconds
Time Before: 0.01070 seconds
Time After: 0.01082 seconds
Time Before: 0.01172 seconds
Time After: 0.01399 seconds
Time Taken: 0.00228 seconds
Time Before: 0.01094 seconds
Time After: 0.01787 seconds
Time Taken: 0.00693 seconds
Time Before: 0.02309 seconds
Time After: 0.02331 seconds
Time Before: 0.02659 seconds
Time After: 0.02782 seconds
Time Before: 0.02231 seconds
Time After: 0.02808 seconds
Time Taken: 0.00578 seconds
Time Before: 0.04775 seconds
Time After: 0.04789 seconds
Time Before: 0.05645 seconds
Time After: 0.05770 seconds
Time Before: 0.06328 seconds
Time After: 0.06345 seconds
Time Before: 0.06595 seconds
Time After: 0.06742 seconds
UPDATE session SET lastactivity = 1785264080, location = '/forums/private.php?do=newpm&explain=1&u=101200' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.08608 seconds
Time After: 0.08640 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
