Time Before: 0.00325 seconds
Time After: 0.00420 seconds
Time Taken: 0.00094 seconds
Time Before: 0.00430 seconds
Time After: 0.00475 seconds
Time Before: 0.00503 seconds
Time After: 0.00515 seconds
Time Before: 0.00607 seconds
Time After: 0.00868 seconds
Time Taken: 0.00261 seconds
Time Before: 0.00522 seconds
Time After: 0.01413 seconds
Time Taken: 0.00890 seconds
Time Before: 0.01714 seconds
Time After: 0.01758 seconds
Time Before: 0.02075 seconds
Time After: 0.02193 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01628 seconds
Time After: 0.02218 seconds
Time Taken: 0.00590 seconds
Time Before: 0.02969 seconds
Time After: 0.02995 seconds
Time Before: 0.03232 seconds
Time After: 0.03357 seconds
Time Before: 0.03697 seconds
Time After: 0.03713 seconds
Time Before: 0.03952 seconds
Time After: 0.04146 seconds
Time Taken: 0.00194 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101204' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.05425 seconds
Time After: 0.05455 seconds
Memory Before: 4,288.695 KB
Memory After: 4,288.938 KB
