Time Before: 0.00142 seconds
Time After: 0.00194 seconds
Time Before: 0.00201 seconds
Time After: 0.00251 seconds
Time Before: 0.00277 seconds
Time After: 0.00296 seconds
Time Before: 0.00382 seconds
Time After: 0.00647 seconds
Time Taken: 0.00265 seconds
Time Before: 0.00304 seconds
Time After: 0.01066 seconds
Time Taken: 0.00762 seconds
Time Before: 0.01262 seconds
Time After: 0.01312 seconds
Time Before: 0.01563 seconds
Time After: 0.01696 seconds
Time Taken: 0.00133 seconds
Time Before: 0.01192 seconds
Time After: 0.01714 seconds
Time Taken: 0.00522 seconds
Time Before: 0.02329 seconds
Time After: 0.02346 seconds
Time Before: 0.02547 seconds
Time After: 0.02676 seconds
Time Before: 0.03063 seconds
Time After: 0.03082 seconds
Time Before: 0.03275 seconds
Time After: 0.03419 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101211' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04705 seconds
Time After: 0.04738 seconds
