Time Before: 0.02214 seconds
Time After: 0.02730 seconds
Time Taken: 0.00516 seconds
Time Before: 0.02737 seconds
Time After: 0.02788 seconds
Time Before: 0.02810 seconds
Time After: 0.02826 seconds
Time Before: 0.02907 seconds
Time After: 0.03197 seconds
Time Taken: 0.00290 seconds
Time Before: 0.02831 seconds
Time After: 0.03665 seconds
Time Taken: 0.00833 seconds
Time Before: 0.04188 seconds
Time After: 0.04251 seconds
Time Taken: 0.00063 seconds
Time Before: 0.04592 seconds
Time After: 0.04723 seconds
Time Taken: 0.00131 seconds
Time Before: 0.04116 seconds
Time After: 0.04746 seconds
Time Taken: 0.00629 seconds
Time Before: 0.08960 seconds
Time After: 0.08974 seconds
Time Before: 0.10844 seconds
Time After: 0.10975 seconds
Time Before: 0.12259 seconds
Time After: 0.12274 seconds
Time Before: 0.12563 seconds
Time After: 0.12728 seconds
Time Taken: 0.00165 seconds
UPDATE session SET lastactivity = 1784895972, location = '/forums/private.php?do=newpm&explain=1&u=101219' WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.14694 seconds
Time After: 0.14724 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
