Time Before: 0.00258 seconds
Time After: 0.00306 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00315 seconds
Time After: 0.00370 seconds
Time Taken: 0.00054 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00394 seconds
Time After: 0.00409 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00491 seconds
Time After: 0.00762 seconds
Time Taken: 0.00271 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00417 seconds
Time After: 0.01104 seconds
Time Taken: 0.00687 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01320 seconds
Time After: 0.01357 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01510 seconds
Time After: 0.01644 seconds
Time Taken: 0.00134 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.01243 seconds
Time After: 0.01663 seconds
Time Taken: 0.00420 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.02413 seconds
Time After: 0.02431 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.03220 seconds
Time After: 0.03344 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.04222 seconds
Time After: 0.04243 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.04553 seconds
Time After: 0.04700 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1772911210, location = '/forums/private.php?do=newpm&explain=1&u=101222' WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.06262 seconds
Time After: 0.06297 seconds
Memory Before: 5,998.719 KB
Memory After: 5,998.945 KB
