Time Before: 0.00464 seconds
Time After: 0.00646 seconds
Time Taken: 0.00182 seconds
Time Before: 0.00654 seconds
Time After: 0.00705 seconds
Time Before: 0.00739 seconds
Time After: 0.00756 seconds
Time Before: 0.00833 seconds
Time After: 0.01059 seconds
Time Taken: 0.00226 seconds
Time Before: 0.00761 seconds
Time After: 0.01472 seconds
Time Taken: 0.00710 seconds
Time Before: 0.01957 seconds
Time After: 0.02000 seconds
Time Before: 0.02268 seconds
Time After: 0.02411 seconds
Time Before: 0.01839 seconds
Time After: 0.02434 seconds
Time Taken: 0.00595 seconds
Time Before: 0.03409 seconds
Time After: 0.03428 seconds
Time Before: 0.04219 seconds
Time After: 0.04361 seconds
Time Before: 0.05075 seconds
Time After: 0.05092 seconds
Time Before: 0.05376 seconds
Time After: 0.05529 seconds
Time Taken: 0.00153 seconds
UPDATE session SET lastactivity = 1788972428, location = '/forums/private.php?do=newpm&explain=1&u=101234', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.07626 seconds
Time After: 0.07660 seconds
