Time Before: 0.00605 seconds
Time After: 0.00764 seconds
Time Taken: 0.00159 seconds
Time Before: 0.00773 seconds
Time After: 0.00813 seconds
Time Before: 0.00841 seconds
Time After: 0.00854 seconds
Time Before: 0.00946 seconds
Time After: 0.01182 seconds
Time Taken: 0.00236 seconds
Time Before: 0.00861 seconds
Time After: 0.01589 seconds
Time Taken: 0.00728 seconds
Time Before: 0.02031 seconds
Time After: 0.02073 seconds
Time Before: 0.02383 seconds
Time After: 0.02500 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01953 seconds
Time After: 0.02522 seconds
Time Taken: 0.00569 seconds
Time Before: 0.04198 seconds
Time After: 0.04212 seconds
Time Before: 0.04950 seconds
Time After: 0.05073 seconds
Time Before: 0.05732 seconds
Time After: 0.05749 seconds
Time Before: 0.05990 seconds
Time After: 0.06137 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101238' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.07956 seconds
Time After: 0.07980 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
