Time Before: 0.00857 seconds
Time After: 0.01311 seconds
Time Taken: 0.00453 seconds
Time Before: 0.01324 seconds
Time After: 0.01369 seconds
Time Before: 0.01393 seconds
Time After: 0.01405 seconds
Time Before: 0.01486 seconds
Time After: 0.01756 seconds
Time Taken: 0.00270 seconds
Time Before: 0.01412 seconds
Time After: 0.02166 seconds
Time Taken: 0.00753 seconds
Time Before: 0.02664 seconds
Time After: 0.02688 seconds
Time Before: 0.02940 seconds
Time After: 0.03240 seconds
Time Taken: 0.00300 seconds
Time Before: 0.02578 seconds
Time After: 0.03270 seconds
Time Taken: 0.00692 seconds
Time Before: 0.05084 seconds
Time After: 0.05098 seconds
Time Before: 0.10977 seconds
Time After: 0.11107 seconds
Time Before: 0.11851 seconds
Time After: 0.11912 seconds
Time Taken: 0.00061 seconds
Time Before: 0.12162 seconds
Time After: 0.12376 seconds
Time Taken: 0.00214 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101249', badlocation = 1 WHERE sessionhash = '86fb755ccb69fa1491ac644ca6ebf439'
Time Before: 0.14386 seconds
Time After: 0.14415 seconds
